Finally getting around to adding a fuel tank sump. I tried searching some but didn't find much on the "best" location for the sump. Any suggestions.
Some pictures of a XDP that I installed on my RCLB. Good quality, but wish it had a drain plug on the bottom of it. I put mine in about the middle of the tank and work's great.
irc, when i put my DRP sump in, i would have put it in about 2" forward of center, maybe 3.
This way you miss the level sending unit and put the sump in the lowest position possible, i measured to dead center and put the pilot hole there and holesawed in, and when the hole opened up i wished i put it in a few inches forward..
Cocoal....if you look at the profile of the tank in the truck, you'll see that the front of the tank is actually the lowest spot becuase it is raked. Not that it matters...because the sump has a "bowl" that will not starve the pump of fuel in nearly any application. For racing, putting the sump in the rear of the tank would make the most sense for those running little to no fuel at the track. The same principle is why most mount fuel cells with the sump and lines facing rearward
Best place is at the back of the tank imo... simple physics
