Stupid newby AFE 5" exhasut exit question
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
MBRP 5 inch, which is not a full 5 inch system, downpipe back aways is 4 inch.
stroke250
I May Be Lost...
Jul 1, 2008
490
Idaho
Here is a 4" AFE on my LML. Sorry just noticed you only wanted 5" pics.
Ridin'GMC
I like red
May 20, 2010
646
23
MA
Magnaflow is the way to go. The 5" starts not too far away from the downpipe. Everything fits well and the clamps are great too. The only thing I didn't like about the exit pipe was it wasn't tucked up nicely to the bed, it hung a but too low for my taste. I took the last section off the tailpipe recently and did the over axle dump. It looks more sleek and I like how it makes the truck rumble a bit more deeper.
Harbin_22
3,858
Southern Indiana
Well thanks for all the help and info. Hit up Henry from creatures of the night performance and ordered it and a Magnaflow downpipe. He has aweaome prices! Truck has to go back to a single 72mmR until the new setup goes on. Should be fun and loud!
Headless_Horseman
Street Sleeper
Sep 27, 2011
73
Stn Mtn. Ga/Iraq
Just throwing this one out there, you mentioned the Flo Pro being straight back...I wanted to throw Flo Pro pics out there to compare. Unfortunately none are super close, but the tip shoots out at a 45 basically coming out just before the taillight. Can't complain on anything hangers are fine, not rusty, sounds great, but good luck on your choices :thumb:
Dozerboy
4,932
511
TX of course
Well I hope you you like the Magnaflow. The one I have exit is 90* front the truck which I wasn't a big fan of. Also you will probable have to run a tip if you don't want soot all over your truck. Mine sooted up pretty bad, but I have a stock turbo and run low boost at cruising speeds.
If you weld up the hangers with a mig you need to paint the welds at least or they will rust out. I use the section of pipe that you cut off to make straps and make a sleeve in the exit that I slid a 5" tip over. That way it looked streamline and kept the soot off my truck.
DMAX497
Sep 27, 2012
398
Utah
5" magnaflow. I cut the exhaust more and angled the tip a little more back...
DMAX497
Sep 27, 2012
398
Utah
4" magnaflow exit... The 5" and 4" exited the same. I like magnaflow exhaust. Nice clamps, easy assembly as well. I even like their muffler. It's quiet till you stomp on it. Guess it's because I like the sounds of the whistle more. But the hood stack has changed all that for me.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,250
395
At Da Beach
Flo pro has the best fit and look...
clrussell
pro-procrastinator
Sep 23, 2013
5,955
422
I just want to verify, but does the the magnaflow exhaust work on LMM? They don't list it as fitting.
Exhaust kits are same 01-10.. Most don't list Lmm for emissions reasons
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,551
534
Central OH
This is mine, less angle than stock but not 90° by any means
Edit: 5" Magnaflow
Dozerboy
4,932
511
TX of course
Is yours up close to the body and level? Mine is and IIRC if I had it sloped down some it was quit 90*. Maybe there is some variance from kit to kit.
Oh wait disregard my posts I just went out and looked. I forgot I had moved the rear hanger to try and give more room when I switch to 35s. Which makes mine at 90*.
