LMM: Stock turbo with drop in batmowheel
mikeholmen
Sep 8, 2011
Airdrie, alberta
Which wheel did you install into the stock turbo? I have done a bigger garrett wheel into the stock turbo. I went with a 66mm inducer, and the stock turbine housing. Been working fairly good. Must done it a few years ago.
mikeholmen
Sep 8, 2011
Airdrie, alberta
It came off a GT40 turbo, can't remember the exact part # for the wheel. Its alot higher flow than the stock turbo. trimmed 3-4mm off the compressor cover inlet, re-balanced the turbo, fresh bearings and electronics. I'll work on getting some pictures. Basically a GT4088VGT, at a fraction of the cost. Probably have $600 into it.
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
Sounds like ill be buying one in the not too distant future, my stock one is sooooo ate up im ashamed to even post a picture of it and sometimes i like to buy things just to be able to say i have it :D
Forever
This 1 time, at band camp
Jan 4, 2009
363
Utah
:roflmao:
So the spool up is better than stock?
Drholliday
286
Gresham, OR
Hows fuel pressure looking on those runs? That same pulse on my stock injector/tips turns out the same times while holding 28k psi. Might be starting to loose rail pressure like I was when I was trying to run faster before the twin CP3's
gmduramax
Shits broke
Jun 12, 2008
4,092
262
Nor cal
Holds 26000. LMM tips are smaller than LBZ tips
