Question: stock turbo pullers
ikeG
Oughta Know Better
Apr 19, 2011
2,462
146
Western PA
www.facebook.com
Track conditions are a big part of my decision. Sometime the start is loose and guys cant get goin, so i dont boost launch then. A good hard track, lighter sled setting, boost launch like you got a big charger will help greatly.
ctrump90
ctrump90
Jan 11, 2012
471
Clare, IL
Ok i need some advice from yall... this will only be my second time pulling Tonight... i have a stock motor stock turbo ppe stage 5 trans with an ats co pilot. Dsp5 with a nice big tune on it. The first time i pulled i put it in four low left the shifter on 3 and just hammered down lol but i accidentally left my valet switch on so i didnt have full power..
I did however make it 274 feet... i had the tbars all the way down and all 4 y
Tires at 35 psi... i have falken rocky mountain 265 70 17 on the truck. I weogh about 6800 lbs as she sits... any advice tips or hints on how to run it or what else i can do to it before tonight? Also is there a way to launch an auto trans in 2nd or third? I didnt think it was possible with an auto. Also should i use the copilot or turn it off? Thanks, corey.
Sent from my MB865 using Tapatalk 2
ctrump90
ctrump90
Jan 11, 2012
471
Clare, IL
O i also forgot that i have an 15lb bottle of dry nitrous in the truck that is supposed to be a 125 horse shot... im gonna run that Tonight to.
Bonestock
1,358
Worland Wy
Our tracks are normally loose and when I had a stock turbo id leave as hard S could every time. 1st gear starts are useless.
This sums it up right here. I usually watch the other trucks to try and determine how they are hooking up and how hard they are leaving. If the conditions appear to be right I load up on boost and launch out of the hole. If the trucks are hooking up hard off the line and bouncing I back off a bit.:D
Bonestock
1,358
Worland Wy
If the class allows, block your rear axle and clamp your springs. Also get your truck as close to 8,000 lbs as possible. Rules will depend on if this is a nadm event or just a local promoter putting on a show at the fair.:thumb:
ctrump90
ctrump90
Jan 11, 2012
471
Clare, IL
Ok im a total newb to suspension. Still learning. I know what clamping springs is but how do u block the axel? And i have to do this on. Very short time period after work or on my lunch at work. And what do u think about how to run it? Gear wise
seth999
Wheeewwwww!!!
Jul 1, 2009
439
Corbin,KY
Let the big dog eat brotha...as soon as that sled moves pin it...
N don't try to kill me on new circle when I'm in my old ladies car:D
seth999
Wheeewwwww!!!
Jul 1, 2009
439
Corbin,KY
It's a road in lex ky...it was few days ago, wish I was in the truck but she is getting a new bedside...a firehydrand jumped out n hit it
You should come to thoroughbreds dyno day...pretty much guarantee you would place top 3
