So, he's lighting up 37s with a stock trans all the way to 3rd huh. My 657hp lb7 won't fry the tires to 3rd.
If you can't fry the tires in 3rd with 500+ HP, you're not trying hard enough. :joker:
Before the build (525 HP / 980 ft-lb at the wheels) I would not only fry my 315/70R17 BFGoodrich's (12.5" x 35") into third, it would light them up from a roll in 3rd. :woott: Makes me worry about driveability once my new motor is together, as I'll be
way past 500 HP.
But yeah, it is best not to fry them if you can help it. The problem is, like many on here, I can't go WOT below 50 MPH or so if I actually want to put power to the pavement.
Everytime I drive an LLY, the more I wish I would have held out for a newer engine for my swap. The VVT's power is so much more linear, and the smoothness is night and day from an LB7.
You still have the stock turbo on your LB7? Both my brother and I have replaced our stock chargers, and it is night and day. You won't get the instant boost of a VVT, but the aftermarket chargers light quicker than stock. Though I still think a (mostly) stock LBZ is the ideal engine.
I imagine it is easier to tune the smoke out of a VVT than a fixed turbo. FYI, I've had pretty good luck getting rid of smoke and hitting boost quickly by turning rail pressure up until it starts to clatter, then crank the timing until you get most of the injection event BTDC. If the mild clatter (think 7.3 powerstroke) bothers you, a bit more pilot injection (or a bit less rail pressure) takes care of it.
