SIKDMAX LMM painfully slow Install/Build Thread
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
What's the problem with going to the hardware store to find the copper washer you need?:confused:. Gm doesn't have "special" washers
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
My orings and coppers are gone, must h ave gotten thrown away when the injectors were with Guy.
Im trying to eliminate a bunch of parts bags and things l aying around in my garage so trying to put as much as I can on now out of the truck. Is that not the way to do it?
ripmf666
15,123
14
47
Wentzville Mo
I have a pdf see if it will attach.Its BD's but really the same thing.
  • 1046200_-_Duramax_Supermax_Turbo.pdf
ripmf666
15,123
14
47
Wentzville Mo
The Gm washers are not flat,They fit tighter around the tip and they have a step on them not the same all the way across.
Found a pic of one.Found better pic.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
So it appears my HTT is a 71mm not 66?
The model number on the tag is HTSS71. Ideas?
Also... Im at the step where I mount the turbo to pedestal and it shows in the pic and says a metal gasket there - wheres that come from? It doesnt look like one came in the kit. Do I Have to buy one? Wouldnt I have my old one, and is it reusable?
13,715
779
The gasket between the turbo and the pedestal should be a T3 gasket. Those aren't used with a stock turbo so you should have one from that, but I would think it should be somewhere with the kit. Should look something like this:
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Jus tlooked at the included list of parts and no.. only gaskets are oil drain and uppipe upper and lower :(
Next thing lol. Putting on manifolds and I didnt take them off so I dont know which bolts go where, I just have the hardware from guy. Does anyone have any up close pics of manifolds on or a diagram showing what bolts go where? Thanks.
13,715
779
I'm going off of memory here, but I think the studs go in the upper outer ends of the manifold and on the longer bolt(s), it's pretty obvious where they go.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
T3 gaskets can be bought from Dodge for less than 5 bucks
I reuse them unless damaged
