I gotcha think I got it mixed up with your LLY, yeah im kinda thinking something similar if I stick with the lb7, but will need trans built... gonna get expensive
Lol luckily my stock trans is still holding. I run it on a 3200uS everyday :woott:
You will be very happy with the BMS sac nozzles. I put about 100 k on the truck that I had those in. Still running strong. You can cut your pulse back to mid 2000 on the big tune and run around 1550 on the small tune. Plenty of power and I picked up a constant couple miles to a gallon.
Add me to the list of Exergy customers being told their injectors were worn out and had metal contamination, with only 20,000 miles.
Subscribed for more long-term info.
Is it bad to say I can't wait for mine to crap out on me now?
Sent from my SAMSUNG-SM-G870A using Tapatalk
I have 3 that are way higher than 4 on balance rates, I have rough idling in drive and I get a light haze occasionally. I ran the upper engine cleaner from gm through it I have an air dog with a cat adapter on the engine. 3, 1 micron filters and I still have bad injectors after 30k miles. Never get it below 1/4 tank and always use diesel kleen with 2 stroke oil, all filters get changed when oil does wich is every 10kUnless you have a lot of pocket change. I always cringe when I see my truck start hazing.
I was contemplating selling the truck seeing as how it is paid off and 2007s and 08s are affordable with my budget now.
These new injectors just saved this truck from the for sale sign. This is its last chance lol
YepSounds like they've already failed on you and need replacing.
Yep
Definitely wouldIf you install the SACs keep us updated like Dave is.
Sounds so familiar! Your not the first one to say that! It's just to bad they operate like that!
Exergy does not operate like that. They test and document very set they do and check the original data when they get sent back to be retested. They take pictures as well. Installation contamination probably is the most often cause of premature failures.
