I bump the first wait for the other guy then bump the second then the lights drop and I stage then run.
How do you stage after the lights drop?
Why don't you try for 11s now?
brake, 3/4 throttle wait till boost hits 10 then once it hits 10 it shoots to 12 then i launch.
What are you gonna do if you ever have to run a Pro tree?
call you Once I get the locker in and or work on tire psi i should be able launch where the trucks likes it which is 16 psi it will hold 16 psi when the brakes are applied all day but right now my front right tire spins pretty good with anything past 12 psi
:witch: Bites her tongue and stands in corner :hug:
I always wanted to try a pro tree.
what about airing down the front right tire some and see what it will do then? your 60ft are really good you just need more power id be happy with 1.6 60ftscall you Once I get the locker in and or work on tire psi i should be able launch where the trucks likes it which is 16 psi it will hold 16 psi when the brakes are applied all day but right now my front right tire spins pretty good with anything past 12 psi
But you dont bracket race remember, so why do you want to be so consistentya but I need consistency. Im gonna run 30 psi in front and 25 in rear then ill try a 16psi launch and see if i can still get the mid 1.6 60's if i can then that will help a lot to keep my truck consistent.
what kind of 60ft's are you hoping for at 16psi?cause the way i am forced to launch makes me inconsistent. When I stage i launch while my psi is still climbing so it is really hard to launch at the same psi every time. If i could get traction at 16psi it would be much easier cause it holds 16 psi.
Nick try more air in the rear. Have somebody film your launch! I bet with 25lb in the rear your truck is transfering too much weight to the back. I know on my DR's anything less then 35lb, I get too much wt. transfer and it spins the front. You can see it on film pretty good. Watch this video 40 seconds in. I tried 25lb, and the front hopped, http://www.youtube.com/watch?v=3AfiMzvMBgI.
