If anybody has a good place to get a lexan rear window I'm having a bit of difficulty getting anyone local to do it.
What?!? :rofl: Shaking a cage isn't the best way I've heard of testing cage strength with or without door bars in. That's like saying to jump up and down on a bridge to see if you could drive a loaded semi over it. While I agree that safety specs weren't made with these trucks in mind, further weakening the cage by removing a diagonal bar is crazy. A 7lb piece of steel will do considerably more for you in a crash than it will left in your pit area. It's cool that it worked out this time but you could just as easily be recounting a crash you had, that hurt you a lot worse than it should have, just because you had the door bars out.
Nhra rules state roll bar must be 1 3/4 thick...can it be built 2in instead? Doubt it would be a great weight difference. ..
It is a 5 point harness, the crotch strap is just bolted through the floor and cross member under the truck. Everything turned out pretty goodIs that a 5 or 4 point harness? If it's a 5, where did you mount the croch strap?
Setup looks killer! Nice work!
