Roll bar time
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
If anybody has a good place to get a lexan rear window I'm having a bit of difficulty getting anyone local to do it.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
I was using it as an example. A cage with a halo and a pillar bars is much more rigid than a 6pt rol bar. Of course we cant truly test the strength on our own safely or economically, but i knew dustin has access to physically comparing the rigidity of both types to just see it.
What?!? :rofl: Shaking a cage isn't the best way I've heard of testing cage strength with or without door bars in. That's like saying to jump up and down on a bridge to see if you could drive a loaded semi over it. While I agree that safety specs weren't made with these trucks in mind, further weakening the cage by removing a diagonal bar is crazy. A 7lb piece of steel will do considerably more for you in a crash than it will left in your pit area. It's cool that it worked out this time but you could just as easily be recounting a crash you had, that hurt you a lot worse than it should have, just because you had the door bars out.
BLKLMM
<<< Slow Mamba
Jan 31, 2010
2,142
Oceanside
Nhra rules state roll bar must be 1 3/4 thick...can it be built 2in instead? Doubt it would be a great weight difference. ..
sickdiesel
Apr 22, 2010
1,019
It can be 2", mine is 2" chromoly.
Oh theres not doubt a 10 point like robs will be stronger than a 6 point, but it still gives me a bit more peace of mind. It may not stop me from getting hurt in a bad incident but may be the difference in walking away and being rolled away lol.
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
It's started
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
Is that a 5 or 4 point harness? If it's a 5, where did you mount the croch strap?
Setup looks killer! Nice work!
It is a 5 point harness, the crotch strap is just bolted through the floor and cross member under the truck. Everything turned out pretty good
