Roll bar kit ........ finished
63chevyll
Projects of Many,None dun
Nov 28, 2009
99
Colorado Springs
ahh, no biggie. I know exactly what your talking about. I like the new ideas people have hear.
rolling over, hitting walls and getting tossed from cars has made me thing of things i never would have thought about before. Tubing size, vehicle weight ect...
my truck in avatar has been in two major crashes and im still ok, thats why we put all the safety equipment in it. :thumb:
Oct 16, 2008
948
12
Idaho
Hope it works out Trent, this could be helpful for a lot of guys if it works out. Just because it's cheaper doesn't mean it's not up to the task. I'm sure you did the research and wouldn't be putting an insufficient bar in the truck. Safety is like horsepower it shouldn't be skimped on. :)
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
My cage was custom made since it had to both comply with NHRA and SCTA rules. It wasn't cheap, but don't remember the price. I'm thinking 3k?
As far as safety goes, our #1 problem is the frame rails are inboard. The hoops have to go outward then up. This is the weakest area in the event of a side impact. Should you get hit in the side (or hit something in the side) the frame rail will not protect you like in a normal car. So I suggest at a minimum to add "rocker bars" which go from the lower end of the main hoop and connect to the lower end of the front hoop. Additional support for this problem can be a lower front/dash bar and a low bar on the main hoop. That will assist the hoops from just folding sideways in a side impact.
Due to the weight of the truck, to insure roof doesn't cave in, we put in diagonal supports for the main hoop that focused on the driver's side.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
An engineer with a masters degree, a draftsman well versed in SolidWorks and BendTech Pro SE, and a professional fabricator who's been in the offroad business for 20 years.
Materials will be 1.5 / 1.75 .120 wall DOM or 1.5 inch Chromo .95/.120 it looks like.
k good thats all Im wondering. You made it sound like *you* were going to design/make them. I love Bend tech. :cool:
(just a little FYI though, there is no "bend tech pro SE". There is bend tech pro, and bend tech SE)
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Correct.... that was a sleepy post while laying in bed on the iphone :thumb:
But yes... this is not me going in the shop with my hydro bender and ordering up 1000 feet of DOM and start bending to see what fits inside my truck :spit:
63chevyll
Nov 28, 2009
99
Colorado Springs
just curious whats the price of DOM going for in other states,
I think our last order was $8.00 per foot if 1 3/4 .120. DOM
I just bought 5 big sticks for my suburban build.....
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
last time I bought some for making a cage, it was a lot cheaper, but I had to go to canada to get it. :)
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Trent Call Alstons Chassis works in Sacramento, and have them make you a copy of my cage. I took all the dimensions for our trucks (without interior). It could be made to work with interior if the back bars are a little longer across the top, and rear seat was moved foward about 2". Below are my 1/2 plate, frame to cage mounts that will be welded in.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Whats the cost on there cage ?
ZR1160
TT Dmax Junkie
Jan 12, 2007
221
Eastern Canada
Here is the frame connection of a 10sec 1/2 ton
63chevyll
Nov 28, 2009
99
Colorado Springs
the frame connections is what i was curious about. I like the 1/2 plate idea, and the Rec tubing works well too.
It would be cool if a truck cage "kit" came with teh frame extensions too.
ZR1160, how did you attatch your rear down bars?
Through cab, or back glass?
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
Is this for an extended cab? Is it a bar or a cage?
TrentNell
Jul 7, 2008
7,543
slc tuah
Got the roll bar kit today , looks really good , all the tubes are pre-notched and came with out riggers to weld to the frame , and the swing out bar option , just a few simple pics i took pieced it together just to get an idea of how it looked .
13,751
821
You gonna put it together in the truck with the duct tape? :D
Looks good.
