Riddle me this...
[email protected]
cmitchell17
Sep 8, 2008
251
I was thinking IAT multiplyiers too. It seems like if IAT gets hot enough it could increase the burn rate so you get more pressure BTDC.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
The results are in. Looks like my "borrowed" time is finally up.
1) 325 psi
2) 310
3) 340
4) 340
5) 360
6) 330
7) 315
8) 285
Pretty much what I figured. No big deal, really, as we all knew it was coming.
Anyone got a set of LBZ rods they want to sell???
I didnt want to respond earlier in this thread Tom because I didnt want to jinx it.......but my original motor did this same thing (the random surge at idle, sometimes runs fine, sometimes theres a strong smell of diesel in the exhaust, other times the exhaust smells fine, no rhyme or reason?? odd) a month or two before it let go (cracked 5 pistons). I dont remember if the rods were shortened or not. I think they might have been a little short??? Ill have to check.
7 or 8 are usually the first rods to go on dmax's, it seems like yours is following the trend. I dont know why? Maybe Eric does?
a "good" LB7/LLY should have ~400+psi or so cold.
ben
724
ECT/IAT Multipliers??
mulitpliers dont do much of anything between 160-230* ECT unless altered from the factory.
extream high fuel temp air temp, cold ECT usually mulitpliers pull fuel/timing not add
[email protected]
cmitchell17
Sep 8, 2008
251
On my stock LLY tune IAT multipliers only added timing at cold IATs but did not change timing at higher temps. But I don't know about the LB7s?
I think the LBZ+ revised all this with timing being pulled according to air temp but I don't know if the tables are avalible with efilive.
2,097
On the plus side, non of the glow plugs broke
Tom is weighing his options, I'm pushing for a stroker
Yep...I won that bet. :rofl: Thanks again for everything...but you know a stroker motor is not in my plans.
Thanks for the ideas guys. We all know how it goes when it comes to running on borrowed time ... but it'll end up alright.
My initial plan is to rebuild with LBZ rods, but its just a matter of just how far to go past that since we're already in there. It adds up pretty quick.
SDP
AKA Dmax15
Dec 20, 2008
261
Port Angeles, WA
Won't you need an LBZ crank also to use the LBZ rods? Along with balancer and flywheel. I'm not positive but I thought I heard you cant use the LBZ rods on an LB7 crank.
724
that would be LBZ piston on a LB7 crank..
LBZ crank has a smaller over all diameter then then LB7 crank.
skintback
Take this one to church
Mar 5, 2007
919
Florida
You can say that again :eek:
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Tom , I think before you pull the motor ( if you ever do ) You owe all of us a all out NOS pass :coolspot: , I will lend you a kit for a weekend :thumb:
2,097
Vaz, I dont think he means a timed 1/4...:rofl:
We could just map out a country road and have at it. :rofl:
dmaxalliTech
Shop Rat
Aug 28, 2006
129
The LBZ rotating parts will all interchange with LB7 rotating parts. The issue runs into balancing. Keep the balancer and flywheel matched to the crank. LBZ crank, use LBZ balancer and flywheel.
Rods and pistons wont matter each way
dmaxalliTech
Shop Rat
Aug 28, 2006
129
Tom will now start taking donations for a block, and any other parts that may not agree with his "going out" party:rofl:
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Rods
I have a set of low miles (10k) rods from my original motor and damper. I will sell cheap. I check the rods before I took the motor apart and they all were.014 to .015 out of the hole. Jeff
2,097
You know Im not that crazy....but if I had unlimited funds to rebuild, it would be interesting and fun to do. Give me a bit, Im working on buying parts.
Jeff, pm sent.
