Prior to installing the LCA's you may want to check the mounting ears for anything like this, some lifts aren't an exact machine fit and they will suck your bolt holes in, I just used a punch and patience and evened them out and the LCA's went in easier.
After installing the LCA I moved onto the stock knuckle and mounted everything finger tight I totally, tighten the lower ball joints first because the upper required me to back up with a
7/32 Allen
18MM ratchet closed end
Once your done mounting the ball joints INSTALL NEW COTTER PINS ON LOWER BALL JOINT
