Racing the 05’
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
Verlon said it is a Precision ML... Hopefully the lock up box will work well enough to pick up s few tenths:D
Same TC I have in my 07, been in there for a long time. Didn't realize you bought Verlon's old truck. Does it still have the 44 gauges along them top edge of the windshield and the hidden compartment in the back seat where he kept his travel arsenal of 100 automatic weapons and 4000 rounds of ammo.:D:D
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I Por patched my mount back together and bolted it. No point in buying a new one just to modify it!
By your 1/8mi time you should be into the 11's easy. Should've done a "track fix" for the MAF and just maxed that bish out
I would have but Rob and I updated my V2 and my my dumb ass forgot to update my efi on the laptop... they wouldn’t play with each other :rofl:
It has 3 gauges and CTS monitor now, to much going on for me. My ocd was pinging driving it back from Shoshone :D I put regular seats in the back as well.
six5creed
1,046
58
N.C.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Pulled my BT lock box out of the 04 and tried it on the 05. Box turned on, armed and disarmed no problem... Hopped in it a few hours later to go to the movies with the wife and test lock up. Shift range inhibited as soon as I put it in gear, FML:rolleyes: Apparently the 5-speed box and the 6-speed conversion don’t jive. Got home at 11:00pm and went to work with a flashlight. Unhooked the wiring at the tcm. I needed the truck to go to work the next morning.
Pulled the box today as I was getting tps errors and brake errors, hopefully they we’re angering the transmission as it had been shifting funky ever since the box.
Also cleaned up some shit wiring on the electric fans I bought used. Controller is gunny bagged so it’s getting a relay and switch Saturday morning before racing.
Bumped lift pump pressure up from 5 psi to 12-13.
Might throw my Mike L super shifter 9,000 springs in the valve body if I’m not to lazy as well.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Any major plans for it?
Short bed, 4 link, gtx4202r single, maxed outs old lb7 injectors, fleece 750 pump, tow flows & lml manifold. That’s what we have laying around currently. I don’t think we even know what size injectors are:rofl: zf will stay for now until I’m ready to piss Jessey off and put an Alli in it:D
Basically whatever my friend Travis and I have laying around. This truck will be a fun but semi cheap build.
lutzjk913
1,704
195
groveport, ohio
Sounds like a blast
