QA1 shocks
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
This has got to be good for 20hp.....:rofl:
Harbin_22
3,858
Southern Indiana
For any of you wondering about single adjustable fronts, TheFunk cuts low 1.50's and high 1.40's and his truck launches beautifully with singles all around.
2,042
Its a good idea, Charles. Adjustable shocks up front do help. If you can make the coilovers work, you'd kill two birds with that one idea.
bluessmax
Tabasco Injected!
Nov 4, 2010
1,149
Lake Charles, la
Better go check it out quick charles... It will be gone Monday getting some suspension and more roll cage happiness! Guess it may be a little faster than I planned :) hehehe
sharpshooter
Jan 2, 2013
5
How have the QA1's been holding up,do they have to be rebuilt often?
Also on the single adjustment QA1's can the rebound be set to be very slow?
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I work right behind a machine shop. Is the QA1 bushing thick enough that I could just have the machine shop bore the hold to 14mm?
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I went ahead and ordered double adjustable fronts and single adjustable rears along with the proper bushings. I plan on installing them this week but wondered if anyone had a baseline setting for street driving?
Harbin_22
3,858
Southern Indiana
I run the rear singles on about 4-6 clicks from soft. They can get really stiff feeling if much higher. Set all the way hard, makes it feel like a log truck. The front doubles, I used to run around 10 clicks from soft compression and around 12 clicks from soft rebound.
