Just put a set of PPE compounds on a guys truck and was wondering if anyone else was running these turbos? Thoughts? What boost are you running? Horse power? Just looking to see where these things perform. Thanks
There industrial injection 20%, which they say is 100hp, or 24lpm. Figured they might be to small. But still curious if anyone's ran a similar set up. The most we've got is 850hp and 1480tq. At 62psi now. Just seems like there's more.
Would changing the injectors really give it that much more? It seems laggy at first and smokes like crazy, rattles a bit, then cleans up on the top. Seems like we're over fueling hard on the bottom.
Who is tuning it? Also FYI my tuner went from 100% overs down to 30% over new industrial injectors and the 30% overs flowed more than his 100s and they cleaned up better. Bigger isn't always better
A 30% over injector can't flow more than a 100% over injector. Of course if II did them who knows what they really flow in the first place. Now if the 100% overs weren't balanced or they were bad then they certainly would smoke a lot. It's true bigger isn't always best depending on the trucks use and goals, but it sure help's to be able to lower pulse width.
