surface clean on the crankshaft
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,701 surface clean on the crankshaft
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,702 I left out you should have
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,703 installed your pistons to the rods
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,704 and then the rings onto the pistons
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,705 ok now back to the rod bearings
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,706 grab a rod and piston and have it ready
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,707 spray the bore down with some wd 40
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,708 and grab the piston and rod
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,709 spray piston with some wd40
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,710 get ring compressor and install piston into bore
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,711 slide down easy watch to make
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,712 you dont hit th crank
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,713 surface with the rods
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,714 take some plastic gauge
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,715 and make sure surface is clean and drie
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,716 lay the plastic gauge green onto the surface
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,717 install the rod cap
TrentNell Finally underway !!!!! Jul 7, 2008 7,543 0 0 44 slc tuah Apr 17, 2009 #5,719 this is way too much tech in fo to be whoreing :rofl:
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,720 make sure you do not turn the crank
