get plastic gauge
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,681 get plastic gauge
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,684 piece on crank surface
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,686 should be alittle
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,688 if all check out
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,689 clean the bearing surface
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,690 and crank shaft surface
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,691 put some engine lube on bearings
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,692 tq main caps for last time Last edited: Apr 17, 2009
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 17, 2009 #5,699 install into the rods
