Pollutes the whole road until reaches operating temp
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
I ordered the Duramax compression tester adaptor today. I guess I'll know next week how the compression is :D
wilsonck
May 8, 2008
206
Calgary, Ab
It will be interesting to see what compression test says.
I have an Lly and last winter would get a lot of smoke. Changed one injector that was similar to your 3.7 one and it helped a lot. Changed another injector about 2 months ago and no smoke this year.
Sent from my HTC Desire using Tapatalk
Sledheadxp800r
Dec 13, 2010
1,151
CT
Mine hazes some on first start up but I don't have the fuel heater or IAH hooked up. I hope its not rods....
I have 2 lb7s. One is my street truck that I'm talking about in this thread(specs in sig) the other one I use just for pulling. The puller has no fuel heater no intake heater and glow plugs are disabled. I fired them both cold at the same time the other day(puller took a couple extra cranks) and the street truck was smoking so bad I could barely see the front of my house and not even a puff out of the puller. So i think it's gotta be internal?
duramax hd
664
CT
I just wanted to get back to you from our talk in your other thread about this. Remember I told you I was going to run some 2 stroke oil through my tank? Well I put about 10 gallons of fuel in, and 8oz of cheap 2 stroke oil, and it appears to have helped out A LOT. I drove my truck to work yesterday as it was under 30 outside yesterday morning and just out of sheer curiosity after your last thread (had my worried a lot). I had a decent cloud of white/blue smoke on startup, and ran rough for total of 3 seconds and then was perfect. No smoke, no nothing. I wish I had a video of my truck this past weekend. I started my truck to take it out with my buddies, and when they were coming down my road, they said it looked likea forrest fire:woott:! Really nad smell of raw fuel as well. I mean this thing was smoking real bad and smelled like a diesel fuel spill. Just wanted to give you something to work with.
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
I have made it a habit to use 2 stroke oil and Stanadyne in every single tank of fuel. whether its in my truck or in Jon's truck, It helps a lot. Less smoke and a little better mpg. Also found it to lessen the lope caused by a worn out FPR
duramax hd
664
CT
I never once in the life of this truck used an additives but I guess im a believer now. Weres the best place to get standyne? what kind of quantity do you use?
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
I get my stanadyne from Ohio Diesel Injection right down the street from my house. Im not sure if they ship items or not i guess you could check their site? Also can buy it on Fleabay:thumb:
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
Cool thanks. Ever since my twins on my race tunes and the cold temps I get alittle white smoke now till I warms and wanna see if it clears it up. Smaller tunes don't smoke at all.
Sledheadxp800r
Dec 13, 2010
1,151
CT
my gm compression tester adaptor finanlly came in today.I just finished the compression test on the left bank
450psi
360psi
440psi
430psi
I'll try to do the right bank tomorrow
mckey73
Ethanol suks make whiskey
Feb 14, 2007
Mine did the same thing last winter but I attributed it to a bad tank of fuel, there was a ton of water in my system and the temps were getting into the teens. Once I got everything taken care of it was much warmer and the problem was not aparent. This winter I have noticed the white smoke on startup again but much less and not every day. The only thing I have not checked is the compression, but I do think about this all the time.
Subscribed!
mckey73
Feb 14, 2007
450psi
360psi
440psi
430psi
Hopefully you just got busy and didn't find anything on the right side. I returned my ECM to stock and haven't seen any smoke at all yet. After I returned to stock I got pulled over about 10 min. later, totally forgot about the speedo calibration. Luckily he was an understanding type of cop. :eek:hgeez:
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Phew. The past two days I have really been looking at my options and this is definitely one option. Any other ideas?
why is this the second thread you are trying to spam with that link to www.newgmengines.com??? Its not even a duramax, its an 8.1. :rolleyes:
Buy a engine new from GM? You've got to be kidding me. Only idiot suckers who dont know anything about trucks/dmax's take their trucks to the dealer and tell them " :confused: ", pay for NEW engines from GM...
Sledheadxp800r
Dec 13, 2010
1,151
CT
Ben whenever I see a post from you I have to check it out because it's either going to be something very useful or you just ranking on someone.
BlkMax
743
Wasilla, AK
450psi
360psi
440psi
430psi
Maybe I am being a dummy here, but it looks like there is no reason to do the other side. You have a bad hole at 360psi, or was that a typo?
Sledheadxp800r
Dec 13, 2010
1,151
CT
No typo. I only want to do the other side just to see. Plus it's not really hard to check.
