Well sounds to me like either your fuel filter is plugged or you have a restriction somewhere between the lift pump and the CP3, you have a major internal leak somewhere allowing fuel to bleed off, or you got yourself a stock CP3 like previously mentioned, or a bad CP3 for that matter.
If it passes bottle tests it's not the FPRV, only other leaks can be external, or through the injectors then.
