Performance Cam Question
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
I bought Smith Bros pushrods when I started my build way back when. Figured it'd be a good idea with the heavier springs and more RPM.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
I have the race springs in mine and i was told i should go to the molly push rods and skipped it for now when i go for bigger tips ill prolly get the push rods and install at that time.
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
I'm still running stock rpm. I think I would benefit allot if I raised it a few hundred. Whats everyone's thoughts on a good rpm to run on a stock engine with a 475?
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
X2 my truck running down the track sounds like im out for a sun drive lol atleast on video :rofl:
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I usually shift a truck with that combo at around 3600 on the 12 , 2-3, 3-4 and 3700-3800 on the 4-5 . maybe more if I am tuning it in person and can feel how hard it is pulling at 3800, but with a stock engine I wouldnt go much higher than 3800 .
LWATSON
Jul 30, 2008
2,587
55
Scotland Neck NC
Thanks for the info, it pulls strong in the upper rpms when I manually shift it but It revs so quickly its hard to drive and watch the tach at the same time.
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
So I know head work would be ideal but can I get away from it for the time being? Help me save a little money plus I am thinking of doing the LLY head swap when my injectors go bad.
At what point is head work needed or suggested.
Dirtymaxx03
3,109
i would say 750+ it would be very beneficial. i dont plan on doing it right away on my build tho
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
I shifted my truck at 4200 the first go around with a s475 and stock bottom end and the valve springs hated me. It wouldn't even go into 5th gear. I changed it to 3800 and went from a 12.18 to a valve floating 5th gear run at 11.94. My valve springs were shot from numerous 4800 sled pull runs " more than i can count" but i also had 4.56 gears while all the drag racing took place. I would say around 3700 is a good place to shift. I think i might back mine down alittle once back together.
SmokeShow
6,818
Lawrenceburg, KY
Like hell, you PM me yours & then I'll know if they're close. :angel:
jk. In all honesty though, I got the specs on an honor system that I wouldn't share them so I feel obligated to be true to my word. It does require reliefs, not sure just how much yet though. It'll be the first time this grind has been in a pull truck. It's been in other high profile engine builds though. We'll see how it goes. It likes RPM apparently so that should be a plus. It hasn't been used in an air-limited application that I know like sled pulling so we don't know how it'll go for sure yet.
SmokeShow
6,818
Lawrenceburg, KY
And I keep forgetting to comment but I've known of a few pullers (all LB7 fwiw) that have bent/broken stock pushrods & even a bigger whoop-daddy one. That one mighta been a fluke though cause it hasn't happened again to my knowledge with the aftermarket ones except the one.
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
Hahaha, i understand, hopefully it works good for you! When are we gonna find out???:D
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
any reviews, good or bad, on the SoCal 8460 cam? I am impressed by its streetability with the s475 but I have nothing to compare it too other than stock motor trucks. It sure likes rpms though, the truck really feels like it has a powerband above 4000.
SmokeShow
6,818
Lawrenceburg, KY
Is there also a 3388 SoCal cam? I've heard really good stuff about a SoCal cam that's xx88 but I was thinking it was 3388 rather than 6688 but maybe not? Whichever one it is, I know it's been in engines competitive nation wide!
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
I think the 3388 is the mild cam that doesnt require reliefs. 6688 is the more aggressive cam.
MarkBroviak
DMax Junkie
2,141
499
Danville Indiana
Yeap, 3388 is the no valve reliefs required cam and is in 90% of my builds out there and it works great. Really nice wide power curve with a ton of torque but doesn't perform as well as the bigger cams upstairs.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
surely Socal has more than these two cams out there..I know I've heard of a 6460 cam as well...I just wondered if those of you who have tried multiple cams have tried these. There seems to be a large movement toward Hamilton cams these days...TTS cams have been tried before and I haven't read any great reviews on them vs the competition. Diesel Pros hasn't been talked about a lot either.
