Performance Cam Question
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
So I am planning my motor build for next winter and have a question about cams.
Of course I am going with a keyed cam but how much HP can a stock cam make? What I am looking for is a DD and a weekend warrior pulling. I know that cams can change the way a turbo lights but what can a stock cam do?
Thanks :D
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
stock cams have went 9 sec 1/4 miles :D. FWIW i think cams in our engines are effiecient for what most of us do. Until you dedicaite a truck for sled pulling or drag racing then you dont really need a cam. I would love to change my cam profile on my engine build but haven't seen enough gains in a off the shelf cam to proof to me i need something different. I know rob hall and others have seen a nice increase in power from cams but they would have to chime in. Sorry for the bad spelling im drunk lol
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Thanks :D
There are other benefits to cams besides peak power , but in a nut shell IMOP you need to decide what RPM you expect to run before a cam can be decided on , if you plan to stay under 4k and have a decent charger a mild cam would work good , if you plan to go higher a bigger cam could net you some decent gains , IMOP the cam and charger both have affect on where peak power will be made . The guys who have made big power on the stock stuff like myself are usually running big compounds or spray , big boost or spray can really help over come flow limitations , but if your running a single and expect big power I dont think the stocker will cut it .
MarkBroviak
DMax Junkie
2,132
462
Danville Indiana
X2, very well put Trent!:thumb:
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Well it will be a solid 800hp truck but that's about it. I don't plan on going for a 1000hp. It will be a single charger S472 at the biggest.
