P0746
M.hulsey91
Apr 25, 2015
137
I have 2005 2500hd with efi live with dsp5. I threw p0746 last night. Had a shop look at it and said the pressure controll solenoid was stuck off? They reset the dtc. Do i need to worry or should i get it rebuilt? Just get it serviced? Idk what to do with it.. suggestions? Please and thanks.
Mike L.
15,681
232
Fullerton CA
P0746 is a slipping clutch that is controlled by trim solenoid A. It's not the solenoid.
Simply stated; you don't have enough trans for the amount of power you are running. Resetting the code is like putting a band aid on a large gash. You no longer see it, but it's still there and will get worse.
M.hulsey91
Apr 25, 2015
137
Thanks. So pretty much avoid hot tune till i get it rebuilt? Will it still be fine to daily drive?
Mike L.
15,681
232
Fullerton CA
I would avoid any tune after the first limp. Even a small tune will sneak up on you and bite you.
Stancedlb7
Cummin Stroke this Duramax
Feb 9, 2015
649
SLC, UTAH
Throw Mikes line upgrade and a shift kit at it. Flat tire your converter flow valve. Even with stock clutches your trans will be ALOT better!
M.hulsey91
Apr 25, 2015
137
Well they got rebuild done but when test driving they said it wasn't shifting right? Said they were going to look at it fri..? I'm just ready to get it back.
Robby05
Jul 25, 2014
498
Spokane, WA
Ohhhh boy. Been there before. Have any idea what parts they installed? Have they done Allison rebuilds before?
If you didn't before you need to now!!!! Find out what exactly is going on & what their plan is to fix it.
M.hulsey91
Apr 25, 2015
137
They said they have done allison trans before. Idk on parts though.
Who are they?
Aamco
Did they "quick relearn" it?
I do not know if they did or not.
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Of course it isn't shifting right, they installed new clutches with different clearances than your old ones had. The tcm has no idea the trans has been refreshed. It still thinks it has X amount of time to fill/release a clutch pack when in fact it has Y amount of time now...
If this shop has built allisons before, they should know this.. Relearn and fast learn.
M.hulsey91
Apr 25, 2015
137
Thanks I'll call and ask em
