I'd also find out about your clearances. If they used aftermarket clutches did they use stock or aftermarket clearances?
I sent you a pm.Most of you guys know more about the Allison than this aamco shop.
You from down here?In Evansville, I could have helped you out with finding a place. Let me know if you have any questions.
Also do you know anyone who does efi live down here?In Evansville, I could have helped you out with finding a place. Let me know if you have any questions.
They replaced the torque converter with the rebuild. He test drove it and said that normal temp is up to 210 found a trans bracket loose and tightened that up. Idk about the temp tho. It got up to 250 and I pulled over to let it cool down.Do you know what was wrong with your last one. I know you said the clutches were burnt? How was the torque converter? Wondering if the torque converter was sending material through and plugged the cooler?
That's what I thought. It was only 90 degrees that dayYou should only be about 100* over ambient.
