clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Swapping turbo stuff, the compressor wheels are the same design, but the FMW is 5 Grams heavily. I am hoping that the cover flows better, from a visual stand point it looks to flow way better. I hope it's not a waste of money, but I have a feeling that the turbine is the real benefit.
That reminds me to call htt
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
Also the new compressor housing don't like the taller exhust pedestals. I guess I just need a excuse to build a new hot pipe:rolleyes::mad:.
Fingers
Village Idiot
1,717
96
White Oak, PA
I've had an oil leak since I put this engine in. PITA. Changed all kinds of gaskets but could never stop or really isolate the source.
Lately, it had been getting worse. Truck was on the rack for new U-Joints, and this time I could see the source. Weeping around one of the plugs in the filter adapter. Ah HA!
Tightened the plug a turn. Went for a ride. Now it is leaking worse! Removed plug, doped and reinstalled. Test ride. Now really bad. Back on the rack. Start engine. Aww $hit. The adapter housing is cracked. Must have been from the start. Made it worse when I snugged up the plug.
I happen to have an extra housing on the shelf. Debating if I should pull the engine to replace or drop the front axle and try and do it in the truck.
5,930
its not all that bad even with the diff in and the engine still installed. just makes a mess. i know merchant now has the inside o-ring you couldnt get before so splitting them apart isnt a big deal anymore when you get it out.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Reminds me I need to order an oil cooler o ring kit
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Waiting on valve springs, I sent Chavis the wrong address..
Then I'll have a long block assembled ready for the truck.
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
5100's showed up to the house today can't wait to get home so she can help in garage
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
Ive also thought about this. Possibly a junction under the hood for +/- leads and allow spots for good ground sources.
There also is a wire running up to the block. How has everyone else wired up the disconnect switch? Currently I have the battery and alternator on one side and the starter and fuse block on the other. Hopefully if needed it will kill a running truck.
minerigger
2,660
Casper, WY
Bringing a good name back to purple parts :D
Looked a little deeper red on prismatic powders but it's grown on me :thumb:
Damn I like that color...what is it? I've got cherry illusions under my hood but I'd rock a turbo that color with my red piping
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Did my first tire rotation on the 420's. I've had them a year and got just at 5k on them. Front were 8/32 and rear were 1/32 :dontknow: :driving: :D
NRA223
May 20, 2015
288
Yesterday i got brand new 285/75/16 Grabber AT2s mounted on the PYOs. Today I aired them down to the PSI i like to run, touched up my undercoating, Did an oil change, fuel filter change, and spin on filter change.
02greysixer
1,829
North Central FL
Stuck injector?
Among other things yes, it's needed injectors for a while. This poor truck hasn't caught a break since 2006. Big ppe tune, big tires, mud, regularly tows heavy with big tune and tires. It's already had heads done once about 6 years ago and it shredded a flex plate about 4 years ago. All 3 times towing extremely heavy with the ppe race tune. No idea how the trans has held up.
Sent from my SAMSUNG-SM-G870A using Tapatalk
