drperry
Jan 4, 2015
21
A couple days ago,but changed all the fuel filters/water separator, and air filter... The S&B filter was wrinkled, lol, so had to buy a new one...
Also, my first full WOT run since the new filters, and my my fuel filter life went to 0... Not good.
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,694
392
P.N.W
Grant AKA 56taskforce and I convoyed 2hrs to drop my truck off at SDP with Scott. BSed him for awhile and finalized everything on the new turbo setup, then jumped in grants truck and came home. Thanks for following me up there Grant.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Attended a class to avoid a ticket and points on my license, stopped by my brother's house to pick up a light and BS for bit. Outside temperature was 112 degrees and expected to reach 117 by 5 PM, after exiting the freeway I now know my fan clutch still works and the transmission stayed a tick under 200 with the new cooler...
http://www.duramaxdiesels.com/forum/showpost.php?p=1002655&postcount=3781
620
You must really enjoy working on that truck!!
Thats ~150k miles worth of road dirt/grimeon/bugs etc those..
Bout 3 hours
Got to put magnetic on the crossman trailer.. lost 2 completely other 2 are pulling 2.5-3 amps between themselves.... should be 12-16A @13.8V
Then load Monday for Alabama
chevor
Highway hauler.
Sep 17, 2015
192
On the Road
That's why I have 1/4" galvanized mesh on the grill and 1/8" fiberglass screen in front of ac coil. Easier to clean than that damn rad.
chevor
Highway hauler.
Sep 17, 2015
192
On the Road
gray fiberglass screen just in front of radiator.
Tried black plastic screen in front of grill on other truck and it just restricts too much air. Then tried this after removing and cleaning out the radiator. Much better. Its easier just to remove the screen when it fills with bugs than it is pulling the radiator gummed up.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Got to see my powder color today, ordering more to do the valve covers and I/c pipes.
Dozerboy
4,918
498
TX of course
That small screen would probably block to much airflow for Adam.
I have 1/4" galvanized screen on the front of my truck. It's worked great but I don't know how much it would help with the kind of mileage Adam puts on his truck. I did it more to keep rocks from dinging up my fins.
620
I picked up some of this stuff.. put it in front of a 36" barrel fan, advertised at ~8500cfm.. and it not only pulled the fan speed down, air flow out it dropped drastically $13.00
The stuff in your grill would be the smallest id go.. which is bigger than the radiator.. somewhere i sucked up an animal or 2 for the amount of hair i washed out of the radiator.l ol
When the fan is on (howling) constantly i notice 1-2mpg drop
pnw_lml
Apr 26, 2016
Noticed a leak in my fass 150 fitting, gf took it back to the place that installed it. Ha fever seen it yet, apparently it's fixed.
minerigger
2,660
Casper, WY
Drained a little trans fluid out of mine...should help it not get so warm. Discovered I have e slow leaks on the trans...over this ****ing truck and it's god forsaken hate toward the transmission I gave it. Check tcase fluid level...didn't drain out the fill whole so it needs more in it. Have an issue with output shaft seals. Need help there
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
Finally got all my battery cables made and hooked up. Hopefully everything works fine.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
Swapping turbo stuff, the compressor wheels are the same design, but the FMW is 5 Grams heavily. I am hoping that the cover flows better, from a visual stand point it looks to flow way better. I hope it's not a waste of money, but I have a feeling that the turbine is the real benefit.
