rgullett83
1,607
Illinois
Damn Josh, just think if that was a paying job... I usually have 5-6 hrs in teardown when I do them(in cab)
moparkxracer
2,309
33
Out and about
Went for a ride with the new twins... Rides nice still have a few things to work on.
picture.php
13,736
806
Yah, no shit. Stock or stroked cp3? Mill and deck?
It's a Fleece CP3K. It flows the same as stock it just has some restrictions removed to keep it from dropping rail higher in the RPM range. I didn't do anything with the heads other than clean them up with a piece of scotch brite and some brake parts cleaner.
I know, right? It's amazing how much easier it is to do this stuff when you lift the cab, and my buddy that helped me out has it down so he can get the cab off in about an hour. It's almost like cheating.
hdrolling
Freedom Defender
May 11, 2011
61
Fayetteville, NC
Added an exhaust tip, 5 inlet 6 outlet 18" long. I did have to cut about 7" off from my exhaust so the tip wasn't sticking out 7" past the fender, but It looks more finished to me now.
Before and after:
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
Both inner tie rods, resealed extension housing to front diff, alignment, oil change, rear diff and transfer case service, tire rotation and fixed a leaking coolant hose. Hopefully its good to go for another 190k. LOL
620
New front bilsteins shocks, cabin air filter mod, 4x4 t case range switch, oil change, new lift pump, ordered 4.56 gears for the back..should be her by COB tomorrow..
If I like them I get the fronts.. Gear swap will Bump my driving rpm range up ~600rpms and allow me to utilize 6th gear. And allow me to use 5/6 gear at 65-70 vs 4/5 gears and take load off engine/transmission
divemonster
Sep 12, 2014
105
What's the cabin air filter mod?
Sent from my SM-G920R4 using Tapatalk
620
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
divemonster
Sep 12, 2014
105
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
01-10 trucks have same heat/AC box.. GM ran cabin filters from the factory for 01/02 stopped in after than... The boss for the filters are still there but not cut out.. GM came out with kit where you cut the hole open and it closes it..
Part number 22759208 lists for $31.00
http://www.dieselplace.com/forum/71...55-cabin-filter-install-2003-2010-trucks.html
Add another thing to the list of parts I need! That's great! I'm always stuck behind big grain trucks on dirt roads.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
I have a bunch of parts sitting on my desk and elsewhere that need fabed or installed. If I had the sump with me this morning I could have installed it. I ran out of diesel in BFE and it would of been a perfect time to install it on the side of the road.
Also the truck is reminding me that it is getting cold out and it wants a couple new injectors.:mad:
