No power after s475 install and retune
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
Ok I just installed my s475 and having issues. No and i mean no power and no codes. I made a custom intake it might be the maf. at an idle it was reading 24.3 g\s don't know if that's my issue. I checked it with the to torque app. My friends stock intake lbz at idle was reading 44.5 g\s. Don't know what it should be or if this could cause this kind of lose in power. My intake manifold pressure read 14.4 psi at idle. Id be scared to pull out in traffic. Any other ideas or tips of what to check. Only code is glow plug circuit a and it doesn't throw a code and that's because there not hooked up yet. I just figure it's my best guess to point to the maf or map
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Maf. An improperly tuned maf will make a truck undrivable. I experienced the same when I built my 5" intake and didn't get it rescaled. Couldn't not even drive the truck.
zf>allison
Apr 30, 2013
3,394
elsberry mo
picture.php
Better yet
zf>allison
Apr 30, 2013
3,394
elsberry mo
That's looking in from the filter side. That's rtv on it. I figured the wires should be exposed to the incoming air?
zf>allison
Apr 30, 2013
3,394
elsberry mo
I mentioned it in my other thread and not this one it's tuned by duramax tuner. I have no way to modified or email tunes. That's why I was looking for the idle range of the maf. So i could tell them and they can adjust it and send me a new ecm
zf>allison
Apr 30, 2013
3,394
elsberry mo
And you told him what size intake to tune for correct?
Yep I wrote a note and taped it to the ecm with all my requests. I said 5 inch intake ( rescale maf ) just like that. But I hear there is alot of different intakes especially one I made that require a few adjustments to get it right
N2BRK
2,041
352
are you near South Jersey? Or maybe near someone else that has a v2 and can help you?
