New DSP-5 switch panel...
Which style DSP-5 switch would you like to see?
  • Total voters
    133
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
ok cool, the gauge pod is something that can be done easily, provided I can find the blank gauge enclosures...which is proving to be difficult. I will probably have to make them. Then the only other problem is that if you have boost/EGT gauges, you'll need to do a 3-pod pillar...
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
yeah i like the gauge pod idea as well......dont like drilling into plastic.
If you get it going I'll take one Ben.
Tyler@MPF
Oct 28, 2008
55
Ben can you give and idea on the dimensions of each options? I like 1 and 2 because they are smaller.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
OK seems like design #2 is the most popular by a long shot. :)
I will make them in either blue, red, or green number displays. Basically just specify when you order. Then there will be two push-buttons; one button to move "up" a tune level, and one button to move "down" a tune level. Now for the level display.
Give me opinions...I can have it show...
"0" (stock) through "4" (hottest tune)
"S" (stock) through "4" (hottest tune)
"1" (stock) through "5" (hottest tune)
The "S" through "4" display is probably the least desireable because, being a standard 8-segment LCD, the "S" will look like "5".
c2500dmax
God Is Good M.M.
Jun 6, 2010
143
nc
i like the gauge pod idea aswell....i also wouldn't mind the #3 option it could be mounted like 05smoker or you guys with the full center console u could mount it in the the bottom cuby hole right above the cut holders i know this would invole some plastic cutting but if he made it smaller where it would just slide down in the cuby and have a nice clean mount/fastner....where it looks as factory as possible.....i wouldn't mind something like that what do you guy think
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
Think the 1-5 would be best
Sent from my DROIDX using Tapatalk
JMDuramaxLB7
YOU SAID MEMBER!!!
Jun 3, 2007
744
Missouri
I have my current knob mounted in my 2 pod pillar right now in between the guages but it would be cool to have a LED readout combined with the knob to say what tune you were on. But then i would have to find a place to put the LED, HMMMM!!!
maine04max
Dec 11, 2008
1,009
the pod idea is cool . anyone could add a trippin mount , put it in there and add another gauge .
GOB_LLY
Less Than Desired
Mar 21, 2010
42
Archie, Mo
What is the timeframe on something like this Ben? I was putting in my new head unit and destroyed my dsp5 switch :rofl::mad: atleast im not stuck in a unstreetable tune but anyways would like to get it fixed asap... if its going to be a while i might just have to go ahead and buy a normal switch, until you get these out... Thanks!
5,848
id really like to have a LCD screen one but have it integraded into the gauge cluster. how does the factory etch of the back crap to pu the numbers and lines on? boy that would look trick right below the tach
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I could definitely do this...but its going to be expensive. Probably more than what 98% of people are going to want to pay.
