New clutches
15,681
233
Thanks Mike. I had no idea about the steels.
Someday Id love to hear your thoughts on two-sided vs one sided clutches....how they compare and what applications both are better designed for.
So far all the OEMs have dropped them because of failure. Single sided clutches are very thin ( .050-.065 ). This does not help heat dissapation. It spreads the load pretty well. They are said to be better in general.
Problem with the Alli is they have no lube slots and oil needs to get to them and lubricate them. This does not happen with the Alli.
AdaMax
Nov 26, 2010
412
Caldwell , Oh
What stall ml converter would be a good dd sledpuller . I will be pulling a gasser to the pull and both will be hookin to the sled . the truck should be 650hp to the rollers this year maybe better with a little luck .
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
what turbo ? if its stock turbo the "ML" would be a good choice , if its a larger turbo the "sled Puller 2300"( depending on turbo size of course) may be what I would go with, until more info is given but pretty much no way around it a phone to who your ordering from with a lot of info is needed to spec a converter 100% .
AdaMax
Nov 26, 2010
412
Caldwell , Oh
who is good to deal with for the ml converter . Can I get a name and number . I need to get figuring what I am going with cause my turbo showed up today . How does the ml converter compare to a suncoast . Thanks
LBZrcks
Jun 2, 2007
5,297
12
SoCal
ML Converter= Mike L.
Call Mike. 714-870-7300
I Had 3 different converters in my 08' two of them were Suncoast, I Liked the ML best out of the 3
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
Well you'll have a LLY coming your way sooner than later then. The harsh shifts and stuff are getting a bit annoying. Just let me know when and how much.:D
techperry
GM Diesel Tech
Jun 1, 2014
47
Earlier in this tread Mike mentioned sealing rings that prevented the rotating assembly from wearing rapidly. Does anyone know a part number or where to purchase these?
