I want to participate in the sled pulls around my area and really don't have a clue on what I need to add to the truck. Also tips on pulling technique would be great also. Thanks guys.
You'll need a cage probably, probably traction bars, good tires, drive shaft loops, the others will chime in
cage??? Only in big tractors, no truck classes even NTPA are required to have cages especially 4x4s, they dont roll.
You will also probably need an SFI jacket and helmet as well as fire extinguiser.
That is the only bitch about twins is you'll have to run the Mod class where in most cases those trucks are setup pretty sweet.
no shit? when is a cage required for pulling? Pro Mod?
What are you guys using to block your suspension with normally??
Very nice. I have bags though so that won't work for me.
Actually, I'm not sure how I am going to be able to do it with the bags in there......
I've never had bags before but can't you just fill them up with air to get the same results as blocks.
