Trac Bars, clamp leaf springs, tie rod sleeves, put blocks inbetween the frame and axle, lower the front end all the way down, good all terrain tire 50 psi in the rear tires and 40 psi in the front hang all your weight in the front remember the sled is pulling down all the time so weight in the back is wasted, put it in 4x4 low tow-haul on put in 2nd gear hold the brakes build a little boost then eas off the brake tell you feel the sled moving good then hammer on it at 100 ft mark manual shift into 3rd and hang on tell the ride is over good luck and post a video of your pull :thumb: and most clubs will let all the safty stuff go for the first couple times you pull just say you are pulling for the first time and that you are there to have fun, then after you get your feet wet and wanna pull alot you will have to do the cross bolts in the down pipe and safty loops and shields around the drive shaft and dont waste the money on a e-locker until you get very serious with pulling you will do fine with the stock locker only thing will happen it that your front tires will just stop spinning when you reach your limit anyways, but you with twins you might be able to pull 4th
