Also Can you take a pic from the top looking down? I would like a better look at the intake runners on the lbz If ya have time that is
Will this one work for you Simon
The Y? You talking about the bridge or the thermostat housing? I did have to take the thremostat housing off to get the hard coolant line that comes up from behind the fan pulley and runs over the top of the intake. I have basically assembled this thing two or three times if you count all the times I've had to take stuff back on because I realized that something has to go underneath something else. I just realized tonight that I have to take the lower oil pan back off because I have to put the bolts upper oil pan bolts into the bellhousing adapter from inside the crankcase.
Made some serious progress today. Just about ready to drop it in.
No, but it doesn't look too difficult to make something like that. How difficult is it to find the fitting? I did put a bunch of assembly lube on all the bearings. Is it absolutely necessary to prime everything?Do you have the pump to prime the motor.
It's Alive!!!! :rockon: :driving: :dancenana: :chicken:
I fired it up at approx. 4pm today. I had a ton of help from several friends of mine. I couldn't have done it without them.
Also, I'd like to once again say thanks to Henry for all the pictures he posted of his build and all the specs he has posted in the GM Specs forum. Without them, this build would have been much more difficult. You're awesome Henry!
