My Country Boy Limo. 06 LBZ
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,694
392
P.N.W
Got home from working out of town and has to post a pic even though most of you have seen a pic of this kind of driveshaft.
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,694
392
P.N.W
Got bored so I put a shine on the driveshaft. Next week I'll be taking it to Driveline Northwest and have them swap rear 1480 u joint to my 1410/1480 combo u joint.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
What the heck is a 1410/1480 combo u joint???
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,694
392
P.N.W
The Driveline came with a 1480 u joint. My truck has 1410's. So in order for the shaft to work on my truck I'll swap the 1480 out with a u joint that's has 1480 and 1410 joints so I can install the drive shaft without swapping out the rear yoke. Hey I'm new to a lot of this so bare with me. Lol
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Ok.... So why don't you just swap out the rear yoke for a 1480 one?
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,694
392
P.N.W
I will eventually, but nothing was wrong with the one on my truck now so decided to save a few bucks and just do the u joint.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I can think of about $195.00 of them plus installation and the possibility of below if not done correctly....:thumb:
http://www.duramaxdiesels.com/forum/showthread.php?t=75391
GM 12471499 Pinion Yoke For 1480 Series U-Joint
Yokes aren't anywhere near that expensive if you know where to buy them. Plus swapping out yokes is easy. Just because idiots screw stuff up, doesn't mean it's difficult.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I understand. Just curious why you wouldn't do it all at once and be done. I didn't realize you could purchase a hybrid U joint like that.
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,694
392
P.N.W
Where could I get a rear yoke at IOWA LLY? So you have a place. I could look at?
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
The 1410 yoke is about $125.00 the 1480 yoke is about $195.00 could that be the cost difference you're thinking about.? Some of us do and do not have access to jobber pricing and the above are readily available prices via the internet..:thumb:
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Greensburg machine in Pennsylvania. I think the last one I bought was around $110
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Greensburg is where I get driveline stuff from. I don't get jobber pricing there. Same price you would get if you called there
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Drivetrain America has the 1480 yoke with balancer for 109.09
There we go. I knew I wasn't crazy! Lol
Here ya go, more information....:D
Don't forget the pinion seal kit, that's where my prices differed,they had the seal kit. The lowest price is not always the best case and does not always include everything you need as is the case with what was posted earlier. You could probably get by with just the seal only and reduce your cost a bit and not use a new nut and washer.
Me, I would not install a new pinion yoke without a new seal, nut and washer. Also, there is a driveline shop owner on DP that recommends you replace the ujoint straps and in this case if you're going to replace the pinion damper replace the capture straps.....
Ferman did recommend using a new nut in his post and the seal kit includes it along with other necessary parts to do the job correctly.
http://www.duramaxdiesels.com/forum/showpost.php?p=1052392&postcount=2
Drivetrain America $158.00 not shipped for both parts
FAST, FREE SHIPPING ON ORDERS OVER $299 IN 3 BUSINESS DAYS OR LESS
http://www.drivetrainamerica.com/74...ferential-pinion-seal-kit-gm-dodge-2500-3500/
http://www.drivetrainamerica.com/40...-5-pinion-flange-end-yoke-dually-1480-series/
GM 12471499 with the seal kit and how I came about on the prices I posted, a complete install minus the straps....
http://www.xtremediesel.com/gm-12471499-pinion-yoke-for-1480-series-u-joint.aspx
http://lincolndieselspecialties.com/i-23846352-duramax-rear-pinion-yoke-11-5-aam-1480-series.html
1410 yoke with the seal only.
http://lincolndieselspecialties.com/i-23846353-duramax-rear-pinion-yoke-11-5-aam-1410-series.html
b16gsr
504
LS MO
Polishing a driveshaft is something I would totally do. Looking forward to more updates.
