So what causes a balance rate to slowly creep up on just one hole? I've saw it as high as +6 then revved it up and it dropped to its normal 2. Just checked it before I shut down for the night and it was at 1.8 then over a min or two it crept up to 2.4.
Went back to the tune I had this afternoon after the back and forth with James about the timing and dropped my speed by 3-4mph and mileage may have improved a little.
I really wish I could have afforded to go with some good new/reman exergy 45's instead of extrude honed on my old bodies but it wasn't in the cards.
Also wish I could remember how to tune my stuff, such as it was, with the help I had from the neens and Josh H it managed to run good. I never could figure out how to use the calculator. It just never made sense to me so I just SOTP tuned lol.
As for the build I was told it was pretty mellow when it came to the machining. Everything was already pretty square on the torque plate hone, and bore. The balancing took the most work and they needed to run an LML balancer on the lml crank which was 60 grams lighter than the lbz one and worked better. As far as actual specs, i haven't got those but I will enquire. I don't believe the final assembly and ptw was that much different from stock though. I'm betting the injectors, tuning, and not being fully broke in combined are my mileage issue sources.
It only has 1000 miles on it now, and although it has developed a slight haze out the PCV vent that wasn't there till after a couple hundred miles into this trip I don't have any oil coming out of the hose-unlike my stock engine that dripped oil all the time. Something to worry about? I dunno. I guess maybe it's loosening up a bit?
