Oil sample will come back bad because of residual zinc additive and break in wear from the last oil that was in it so no point.Pull an oil sample. It will tell you whats going on. Have you done a mechanical oil pressure test yet? Your truck sat for a long time, sensors dont like that.
Oil pressure never changed since the swap to synthetic and it's above min at idle and just a couple pounds below at 1800 so I'm not terribly worried. If it drops about 5 lbs or so in the next little while then I will be concerned. I have no tools, place, or time to do a mechanical gauge install right now though.
I believe I got H bearings installed not HX so the clearance should be close to stock.
I wish the builder had been a little more diligent in keeping the measurements.....
