Stall then roll Into it. On setting 3.
Watch "Stall then roll into throttle" on YouTube
https://youtu.be/H4jMRyMrPlA
Update: Don't have time to wrench on it anymore (took too much time off already) so I sent it up to Tony Rizzi in Washington Ga, originally wanted to send it to Evan but he's swamped anyway. He just got back with me. Trans stripped the hub and planet then spit metal fragments so the planet gears on the p2 chewed them up. The c4 is also toast, clutches were glazed. Waiting on billet parts and sungear to show up.
Still unsure as to what made it shift so hard but spinning in 4th when I eased into it then catching traction didn't help the situation. He hasn't broke the vb down yet so maybe a stuck valve?
That's runnin good what were your EGT'S towards the end?Ok got my new tune on and a little bit of time feeling her out. This is kill tune after launch I rolled into half throttle to keep from smoking the tires, at 60 I rolled into full throttle with full throttle at about 80. Definitely going to have a problem putting power to the ground. This is on 305 all terrains no traction bars.
Watch "Kill tune" on YouTube
https://youtu.be/0wbLr09MD6Q
It was shifting early because I was only half throttle at those points. It shifted closer to 3800 when I was WOT.Sounds like it was getting down! Not sure if you dynoed it yet, but I would be willing to bet it would run harder if you set all shift points around the 3350 range.
Open trans tune:
Efi engine operation>Shift points>WOT RPM, and just set all cells to 3350 in all gears
