Bob told me to go 60s if i want it clean and 80s if i wanted to get serious........
Told him i was going 70s because i was 1/2 ass serious:joker:
I wish I would have went with 100 overs vs my 60s
I dont think i would go over 100 If i were you im sure your pushing a decent amout more air then i am but dam thats a ton of fuel man.IMOon the low tunes I can't tell a difference between the 60 overs and stock, they drive that nice. But my turbo kit is starving for fuel which makes me want 100 overs at least
If you have the valve reliefs and ported head i would definitely suggest a cam. And as far as injectors go, my exergy 60 overs run like stock when they are on the small tune and have plenty of flow for the big tunes. I'd be curious to see how clean the 100s would run with good tuning thoughIm hoping with tuning and the turbo set up that E.D. is putting together for me the 100's will be fine on lower settings. Now that i decided to port the heads and I've got the mahle pistons with reliefs... Ive been thinking about a cam. Not sure if id need it or not. But the added lift and duration sure cant hurt airflow!
Ok... Who wants to talk cams... Like which one would work best for my build. If needed ill type out a list of everything ive got.
