If I knew how to post pics I would,it was used for towing and a little racing.
You can e-mail them to me at [email protected] and I will attach them if you want.
Well, I finally took the time to read the whole Dodge CR melting thread instead of just the first post. They seem to be focusing on the differences between CR model years and also water injection, piston design, RPM, injectors, tuning, and steel pistons.
It was actually refreshing to read a thread there where the shops and moderators weren't fighting.
Big injectors didn't seem to help them if I'm reading it correctly.
Here are a couple of pics after I put No 7 rod out the side. We know for sure we were well over 750hp at this time. The rods all were bent until no 7 broke. This was with a Supercharger into a GT45 and egts would struggle to get past 1300. The pistons (except for No7 that got mashed) looked in excellent shape apart from where some debri from an air filter has bounced around on top of No5. im not sure on all the details of the tune that was in this at the time but Mike done the tune, he may like to comment on this. Im way at the back of the bus as far as diesels go but any opinions on this one?
how long had you been running that much power Mick ?
Would excessive timing be the culprit in this case?
I'm not familiar with diablo's tunes.
Stock injectors, dual cp3's, 26,000 rail and trying to keep the shot in the bowl. The thinking at the time was more pressure less pw? I don't know, egt's were low " for us ". I couldn't make up my mind if supercharged and having lower egt's and less drive pressure out weighed higher turbo drive pressure with higher " for us " egt's waiting for the turbocharger to come on and dealing with the smoke?
Wow, looks like everything was in the right order........looks like just a structural failure of the stock rod??
Well, I know a Snow system won't stop it. Perhaps a bigger system might.
I tried to order a "big" system at a Dodge shop, and when they found out who I was, they stopped talking to me.
I am guessing no. I have looked at diablo predator tunes and they add little to no timing and a chit load of pw iirc the 85hp tune from diablo adds no timing and has 3000 usec of PW i would imagine with the 120 tune loaded and the power puck the rails were seeing low numbers
Why do you think rods bend you nitwit? Hit your thumb with a hammer and tell me we didn't have a structure failure.
After much thought, it seems that high timing about 30* with short duration and adequate RP25k or so is looking to be the best on paper for the d-max....
with 60% or bigger injectors...
pretty vague statement considering that to figure propper timing , you need to know a duration and rpm .
