Buck is still sporting good old LB7 heads and injectors. RPM's really aren't a problem with LB7's or LLY's. I know of at least one LLY that makes power to 5800 RPM's.
My understanding the cups are now permanent not being held down.
Hey Trent, im brinning a head and cup into a company monday that specializes in keeping things together (ie spark plugs in heads, locks, thread retainers ect) im curious to see what they come up with.
Or just simply switch to an LLY top end and have no more issues with injector cups or pulling valve covers to swap injectors.
Their suggestion was to make cups that are threaded on the outside, and use a spanner wrench to install, along with making a fixture using the head bolt mounts to tap the head.
def still a consideration , if it wasn't for already having full ported heads , and all new bodies and tips LB7 style i would be making the switch , but to expensive as of right now to start over .Or just simply switch to an LLY top end and have no more issues with injector cups or pulling valve covers to swap injectors.
That is what we have in the works for winter time , custom made stainless cups , and using a CNC to thread the head.
yea i get you on the to expensive to start over part Trent, but i really hope you get it figured out. i know you will take the best route for you. cant wait to see your truck back on the track
Well see how it holds up the rest of the year , truck should be up and going again next week and maybe to the track for weekend on the edge if everything comes together right :thumb:
who is making aluminum cups? what grade aluminum are people using? i pushed one out on my 3.0 truck, this winter i might look into getting some welded in.
