Info: Major internal damage from lifted cups
9,905
151
Wow how did I miss this one?? Sorry to hear Trent. Hopefully it all gets sorted this winter-I want to see some low low 9's out of that girl!!
I think Pat said it best though - GM fixed the problem about 7 years ago. If you are pushing the limits of a first gen design, then I think it would be best to just swap everything over to an LBZ or LMM and eliminate the issue all together. Don't bother with the LLY's, they are too slow!:D:coolspot:
Other than that something like what Simon was talking about - a hold-down that holds both sides of the injector down, one with two studs, would probably work too. Maybe even using shims to keep the hold-down square to the block may not be a bad idea either......
Baker Lock is definetly worth trying as well! I remember trying to get plug valves and chokes apart with that stuff on the threads. Heat and Beat is the only way!!
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
Think someone should talk to Buck, they did something totally different with their LB7 heads with the cups, but I'm not sure if they are still running the LB7 or not. Most guys going for the big HP have switched to the LBZ. Not only for the heads but the RPM as well.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Last time I was told Buck is still sporting lb7 heads.:thumb: this was just recently. As far as what's done to them I don't know:D
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Hey Trent, im brinning a head and cup into a company monday that specializes in keeping things together:D (ie spark plugs in heads, locks, thread retainers ect) im curious to see what they come up with.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Buck is still sporting good old LB7 heads and injectors. RPM's really aren't a problem with LB7's or LLY's. I know of at least one LLY that makes power to 5800 RPM's.
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
My understanding the cups are now permanent not being held down.
I heard the same - aluminum cups welded in. Not sure if it is true but that is the route we have been considering for some time now. We have them drawn up now. Just waiting to hear back on pricing for machining them.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Their suggestion was to make cups that are threaded on the outside, and use a spanner wrench to install, along with making a fixture using the head bolt mounts to tap the head.
paint94979
Beer Nazi
Sep 18, 2006
11,715
Or just simply switch to an LLY top end and have no more issues with injector cups or pulling valve covers to swap injectors. :D
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
That is what we have in the works for winter time , custom made stainless cups , and using a CNC to thread the head.
def still a consideration , if it wasn't for already having full ported heads , and all new bodies and tips LB7 style i would be making the switch , but to expensive as of right now to start over .
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
yea i get you on the to expensive to start over part Trent, but i really hope you get it figured out. i know you will take the best route for you. cant wait to see your truck back on the track
TrentNell
Jul 7, 2008
7,543
slc tuah
Well see how it holds up the rest of the year , truck should be up and going again next week and maybe to the track for weekend on the edge if everything comes together right :thumb:
9,905
151
Fingers crossed for ya man!!
duramaxsandwich
Mar 30, 2009
206
who is making aluminum cups? what grade aluminum are people using? i pushed one out on my 3.0 truck, this winter i might look into getting some welded in.
