Made a few T&T passes yesterday .
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
went out to the track yesterday for a T&T and made 3 passes , good news is I was finally able to solve some issues I have been fighting for 2 years and the truck was getting really good ET for the MPH , bad news is lifted a cup on the 3rd pass :rolleyes::toetap::banghead:, hopefully have it up and going for another time out with in a week or 2 depending on if there was any damadge cause this time .
1st pass was a soft launch on a tiny tune
12.0 @ 110.** 1.88 60ft , 7.6 1/8 mile
all was good so moved it to tune 2, another soft launch but harder than the last .
60 ft 1.66
330 4.478
1/8 6.862 @101.92
1000 8.973
1/4 10.75 @ 124
That pass was great just needed a harder launch and some more fuel , turned it up a few hundred more USEC and launched a lot harder but went too hard and blew through the tires . but we lifted a cup before the 1/8 mile , sadly since the rad is in the bed i didn't know until the run was over it had lost water just felt the truck nose over a bit, it sucks to finally have the truck ET so well and not hold together long enough to even put a real tune it in :( , ill post some vids in a bit .
60 ft 1.65
330 4.416
1/8 6.704 @ 106.39
1000 8.711
1/4 10.41 @ 131
TrentNell
Jul 7, 2008
7,543
slc tuah
:( But, I bet it felt great to get back to the track.
Thanks Kat , it felt really good to get back out !
Sorry to hear you are still fighting issues but I am glad to hear that it is back on the track. Keep at it!
Thanks Jon , it sucks i was hoping the billet hold down would buy me a little more time , all i really needed was for them to hold a few times out . , even put 4 new gages in the truck to closely monitor boost from both stages , drive pressure , EGT's , and all were well in check , boost never even went over 70 on those small tunes, not to mention these cast pistons are over 1.5 points lower on compression than my forged are .
Righteyeblind
712
Fairbanks, AK
Nice numbers for some shakedown. Sounds like you are going to need to go with different heads or weld those cups. Your truck has got me worried and I think I am going to go to LLY heads next year. Congrats for sure though.
TrentNell
Jul 7, 2008
7,543
slc tuah
I def knew i would need more in the long run and have everything lined out to make it happen over the winter , but was hoping the billet hold down would make them last a while , all they had to do is last 2 times out and the year is pretty much over here , well see what happens .............
5,812
damn it trent! Well, running a 12.0 on the smallest tune and 10.70 on the next tune up aint too bad :D
1,865
Man, wouldnt we all like to run 10.75 on a mild launch. Wow.
Time to call DTS about those heads and get the cups welded in, Trent. You were the first person I thought of when they posted those.
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
There are some guys out there who know how to weld the ss cups to the heads. I don't think i would chance it, therefore I forewent the whole issue. Knowing what I know now, id have used lmm heads and not lly heads, though the difference is minimal.
TrentNell
Jul 7, 2008
7,543
slc tuah
Lilly heads man,,,,,,,,,,,,,,:thumb:
I have a set here and there still not off the table just not enough time before the year is up .
it was pretty amazing , it picked up that much by a 500 usec change in the tune , picked up another 6-7 MPH going a couple hundred more on the next pass .
I am still happy with the passes i made yesterday considering how much mit was turned up , but when the trucks went almost a second faster on much less hardware ............
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
10
Wyoming
1.60 60' is considered "mild"??? :confused:
Trent what type of lock-tite are you using to seal the cups, and are you using new cups and o-rings each time? How long are you letting them sit, etc?
IMO your only option from now on is LLY+ heads or threaded/welded cups. Provided the cups were installed/seated 100% correctly, it seems the billet hold-downs arent clamping them tight enough. :(
Nice runs though, cant wait to see what she'll do when you crank it up. :thumb:
Any video?
duramini2001
On a Time Out
Sep 30, 2006
639
40
Highland, Ut
hey trent were the billet hold downs on your truck for that run?? Im not sure where your cup prob is coming from man, i have 14,300 miles on my engine this year and not one cup problem or pressure issue yet, my hold downs are 5 years old and running, im setting them to 70 foot pounds if that helps, red lock tight, and oil on the cup o rings for pre lube?? im sure you already know all this but sucks your having all these cup probs?
