lowered truck pics
20miller12
Aug 27, 2014
24
[/url]
They only have two tires with them and the kiddo was fussy so here is a quick few
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
Found out yesterday I guess plaza didn't level my torsion bars before aligning my truck like I asked so it's an inch off driver side to passenger side. Is an inch enough if I level it I'll have to align it again?
Dmeiborg
Oct 12, 2013
49
Not REALLY lowered, but 2" shackles in rear. Front is cranked a little to match
Soon to be removing overload, and another leaf, and I'll let the front down to match
I love those headlights. You do it yourself, or buy them? Thanks!
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
I dropped my t bars 5 turns below stock once and didn't get it aligned. I drove it like that for probably a year and didn't notice any negative effect, no tire wear or pulling. Don't know what would happen if you only dropped one side, I think you'd be ok with only dropping an inch.
hotrodbones
Sep 9, 2014
Nitto 420 tire wear
Do the Nitto 420's wear down fast when towing? I just picked up some 20x9s and was going to run some 285/50R20s but worried about tire wear towing an enclosed car hauler.
20miller12
Aug 27, 2014
24
they look better then I thought they would
22x9.5 with 285/45/22 420s stock torsion bolts removed and drop shackles in the rear
zf>allison
Apr 30, 2013
3,394
elsberry mo
My trucks about done and I'm gonna need some shocks. I want the rancho 9000s based on reading, but what is the length or part number I need for slammed t bars and 3 inch drop shackles? Or should I measure and call rancho?
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
They are zero help, unless you are lifted they can't tell you a damn thing. I just went on amazon and found the ones with the least amount of overall length. Iirc the shortest you can get is 2" shorter than stock.
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
I got the 9000xl.
I'll get the part #'s but the ones I got didn't fit right away... fronts were fine but I had to drive out the bushing sleeves for the rear ones, some might say that's not right bit they are just fine now, I might just get accelerated bushing wear in the rear.
I could not find any dimensions for mounting holes for them that was why I ended up with what I got bit I'm happy
Edit: RS999029 and RS999113
