Low Oil Pressure?
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
So I have been battling low oil pressure since I got my motor put back together, I put a brand new OEM oil pump in with the motor.
The symptoms are I will start it cold, and oil pressure is around where it should be, but then as it heats up my oil pressure drops down to around 13-15psi at idle. I only notice it happens when I run it consistently for a longer period of time. at 2000 rpm's it reads around 30 psi.
Tomorrow I am going to get an oil temp gauge to install, but has anyone else ever had similar issues? I think it might have something to do with my bottom end being filled, which could be making my oil run hotter which would make it thinner. I run 15w-40.
any input is more than appreciated,
Caden
Cknight199
Aug 23, 2012
1,827
I should add, upon cold startup (70* coolant temp) it reads around 72psi. As the motor warms up it will begin to run lower and lower the longer I run the motor, until it idles at around 15 psi.
rayramsay75
Mar 11, 2015
How do start a conversation
I also have the low oil pressure when warmed up and the low pressure on my fuel rail the no start problem
Cknight199
Aug 23, 2012
1,827
Not sure how that is related to this thread... I would suggest starting your own thread or doing some more research so others can help your situation.
