Low Oil Pressure?
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
between normal driving and light towing over the pass last weekend with a completely unideal setup, ie. big turbos, filled block, etc i didnt see oil pressure dropping lower at 65 or idle honestly.
baggedLB7
Goer
May 1, 2011
688
Utah
Realistically, can the oil even get hot enough to loose noticeable oil pressure because of it thinning?
Yes.
Before I did my oil cooler and I was cheaking my oil temps I took a trip over parleys with the boat on a hot day and held speed and rpms as consistant as I could from the bottom to the top.
My oil temp went from 225 to 283 and my oil psi dropped from 38 to 25.
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
Yes.
But what about on a truck that never tows, and it happens just highway driving?
Cknight199
Aug 23, 2012
1,827
Update. Motor is back together, this time with a melling pump. Oil is where it should be stock, going to try a different weight oil next oil change and see how much it improves. This motors twin did the same and picked up much better pressure.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
That Lucas oil stabilizer works pretty well. Mine stays above 30 psi now. Before I was getting into the 20s at wot
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I just built my motor. New oem pump is at 19-20 idling with engine temp at 190. That's with 15-40 delvac My mains are just a hair over .002. Not sure if the oil holes in rods matter or not. But like stated above. Main clearences have a lot to do with it.
