Look what UPS dropped off yesterday!
knagel
weakest link finder
Jun 4, 2007
221
Central, Iowa
They shorted the 4094VA on the turbine... It's 67mm exducer.. Cheetah is 71mm.. I'm building a turbo with that turbine tomorrow to test.
Brayden
How were you able to get the turbine wheel that is available in the 4094avnt. I checked all over and there are none available except if you buy the whole turbo. This is why I stopped trying to build my own. If they were available, I would have gladly bought one from you (or one that was similar ie: the one you use) when I was trying to build my own turbo.
I am interested in what you come up with on your tests of the 4094avnt. I am happy with it so far. I ran against one of your 71's last year and I was stock. We'll see if he has it dialed in this year.
Kevin
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Turbo's
I think some people miss the fact that some guys can go fast with anything and some guys will go slow with everything! Thats not a slam on anyone but some will spend more time and just make things happen. Drivers, setup, tuning and many many things to go wrong. Normally only one thing to go right. Jeff
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
The up pipes really helped then:)
I just dont understand how you got it that low with that DP.:)..that is near double.
You where sustaing a good rail pressure obviously.....but thats better than stock with a higher PW...this is a stock turbo?
Actually I wasn't holding the best rail pressure at the time - it would dip under 20K. And all of that data was on my 68mm Cheetah. The drive pressure surprised the hell outta me since the EGTs were so low.
