LML Twins and Opinions
ZeroGravity58
1,401
51
Maryland
I wonder why you have to run two separate feed lines? The older MPI twin kit I have used the galley to feed both turbos and you never heard of turbo failures. Seems like overkill to me?
ZeroGravity58
1,401
51
Maryland
Cause you starve the cam unless it's a lml block.
I understand the factory setup from the galley. But you don't hear of turbo failures. What I was getting at is I feed both turbos with the oil feed from the pass side of the block. Why do you need twin feeds from both sides of the block? Seem like overkill.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Depends on the turbos being used. A s400 requires a 6an feed line. Stock and s300s use a 4an. I have seen turbos fail cause of oil.
Dm23
400
125
Socal
Do any of you guys have a step by step way to flash the ecm. I get a e86a code a 050c code and 0536 code.
M.A.M.
429
Ohio
The 0536 seems to indicate that the tune wasn’t saved to allow remote flashing. Your tuner will need to adjust that if that’s the case.
Dm23
400
125
Socal
By the way sorry Op for jacking this thread.
The only thing I could’ve done wrong is get rid of some extra letters or numbers that came up on the efi live website when I had to convert the numbered/lettered lines.
Dm23
400
125
Socal
I’ll try. I don’t really know how to post pictures. And I dont have anything fancy as in my turbo is factory color just like stock.
Dm23
400
125
Socal
Not a good picture. But I can take more tomorrow up close and send them to you
FROGMAN524
613
Well good news maybe, found a local shop that I had never heard about that is quoting me to install the turbo and hot side pipe. Waiting on a call back right now with price.
