I would not check pressures with a transducer as they can be way off. A liquid filled gauge is preferred. I have never seen pressure any higher than 250 psi on an LML with the main mod disconnected. I tested a A50 TCM 5 years ago on my truck and saw 250 psi. I also saw higher temps with both these mods. Higher pressure will keep the trans alive longer no doubt; but you have shit clutches to begin with and converter clutch does not like anything above 800 ft lb of tq before the lining begins to break off.
I'll just keep doing things my way with building the trans.
Yea, when Brad checked with his liquid gauge he said hit and miss on some trucks, but he did see 280 as well... He stated same thing you did though- that some will hit relief and not make more than 250, while others will.
Regardless, we can run it to its max setpoint with a simple calibration. As you know (and I have stated a few times) this is NOT A REPLACEMENT for built trans.... but longevity will for sure go up with the pressure added. If someone is spending the money to get big power - plan on spending it on a built trans over time as well... but until then, I see no reason to not run a calibration that allows for higher line.
Thanks for your feedback, Mike. Always appreciated!:hug:
