LML Internals
jbgmc
Feb 8, 2011
15
In a house
Pull a KillerBee and buy up the countries supply and corner the market! Order 50,000 units locally. :woott: :roflmao: :woott:
That thought crossed our minds here. May be ordering a set of the oversized pistons too. I'll see what I can do to post a piccy poo or two.
jbgmc
Feb 8, 2011
15
In a house
Here are the pics. Don't drool in your keyboards. :rofl:
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
it might be the angle of the pics, but is the bowl smaller in diameter? Or does the "lip" overhang more?
Do the LML rods have holes for wrist pin lubrication?
jbgmc
Feb 8, 2011
15
In a house
No wrist pin lubrication holes and the lip does hang over more. As for the size of the hole I'm not sure if it is different or not. (no remarks there!) If anyone wants some different angles let me know and I will see what I can do.
ripmf666
15,123
14
47
Wentzville Mo
They changed the oil pressures on the lml and lbz some.
Lubrication System
  • Oil Capacity - with Filter
10 qt
9.5 L
  • Oil Capacity - without Filter
9.2 qt
8.7 L
  • Oil Pressure - Minimum- Hot - at idle
98 KPa
14 psi
  • Oil Pressure - Minimum - 1800 RPM
294 KPa
42 psi
  • Oil Relief Valve Opening Pressure
441 KPa
64 psi
  • Piston Cooling Jet Valve Opening Pressure
196 KPa
29 psi
LML
Lubrication System
10 qt
9.5 L
9.2 qt
8.7 L
48 KPa
7 psi
  • Oil Pressure - Minimum - Hot - 1800 RPM
193 KPa
28 psi
441 KPa
64 psi
176-216 KPa
26-31 psi
easier to read the specs here
http://www.duramaxdiesels.com/forum/showthread.php?t=6131
http://www.duramaxdiesels.com/forum/showthread.php?t=29598
2,064
Just larger pics next time. :D Thanks for sharing so far, though.
Trippin
SoCal Diesel
Aug 10, 2006
663
From the left: LB7......LBZ/LMM........LML
JMK777
16's, but i keep em clean
Mar 20, 2008
1,433
5
Moss Beach
looks like the lml has a smaller oil passage leaving more metal where needed. also looks like there is more metal below the oil ring.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Interesting! Great picture Guy, and thank-you for posting a high-res version. :cool:
Id be willing to build a motor with de-lipped LML pistons and beat the crap out of it...we've got lots of extra blocks and cranks here.
De-lipped LML piston I would think would be ~15.5:1??? Stock is 16.0:1
EDIT: Actually looking at the taper of the rod small end on the LML....will a carillo or LBZ rod even fit in an LML piston...?
