LBZ race tune
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
You're launching it really soft which is part of the reason your times are so slow, but even still, your MPH is about 5-10 lower than what it should be. 8100 Power trapped almost 80 with this tune, and he doesn't have a lift pump or a built trans. How heavy is your truck? Something doesn't seem right.
I weighed it for a truck pull weeks ago and it was 7070lbs. Fastest time was .54 r/t, 2.5 60', 9.7 @ 73.62
Dec 2, 2006
1,696
TN
That 2.5 60 is the killer.
I came from a best of a 8.9 with a 2.3 (??) 60ft and dropped to a 8.5 best with a 1.8 or 1.7 60ft.
4x4 launch @ around 2000 RPMS.
Texasmax
Sep 20, 2007
99
DFW-Texas
We can use mine to tune it. We'll just have to work something out on the license. We'll have to get to the track before October so you have it running good in front of all the other diesels at the NADM/ODRA race. I'm gonna need to get my truck tuned up and see what it will do anyway.
I could probably get the cable that set the tune to my spare.
Dix
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
Sled pulled with this tune tonight. It hauled ass like never before Josh ! 2nd place in 2 classes ~324 and 34? feet.
13,765
834
Awesome! Glad to hear you had a little better success with it on the sled pulling track than you did at the race track.
1,696
TN
Yea, I had to feather it almost halfway to keep the tires under it.
I was running a different tune Friday night, but I experienced the same thing. I had traction issues all the way down the track, a constant chirp as in the tires was still looking for traction..:D
Dec 2, 2006
1,696
TN
Have you been to the track yet Chris to see if you could get anymore out of it?
I'm going this Friday night, weather permitting, as Friday night is was raining. :(
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
Nothing yet. I'm goin to the NHRDA finals in Bowling Green oct. 24 if nothing sooner to run test-n-tune. It's a lot better track anyway
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
2 more days! Trucks going on a slight diet. Guess I'll load this tomorrow and learn it before then. Come on 12's :hug:
CCSBLBZ
Dec 11, 2009
This the script of 3624 stock or Josh's tune? I didn't know if there was one for an o6 LLY and a different one for an LBZ both 3624. I found the LLY one but didn't know if it mattered.
If it is a script LLY, LBZ , and mostly OS #'s don't matter That's why we have scripts.
cody lb7
Jan 12, 2011
21
do you know what size efi tune you can safely run on a stock allison and lbz motor with just cold air and 5 inch exhaust
Colt
Jul 23, 2010
523
Kinda' said 100hp over stock is probably alright on trans. Still have to know it's history and just use it with only enough aggression to hold up. Some do more and luck out but it will limp someday and then it's softer and limps easier because you will hammer it once you know how that truck can get it. It's like a habit more and more seems like. Oh well...
